Motion detection range (video doorbell)
  • 4 Replies
  • 1694 Views
KroKis
My Arlo Video Doorbell only detects movement up to 3 meters(10feet), from 3 meters there is no longer any notification or recording.
On test motion, same, led dont light up to 3 meters.
Is this normal? Or is a defective u it?
Is this detection a person approaching the door?  Or something else?
What motion detection threshold are you using?
KroKis
people who pass in front of arlo video doorbell does not detect them if they are more than 3 meters away
I have set the sensor to maximum 100
Are you setting the sensitivity in your modes and rules? The motion test is just a test. Also, is it possible that the plastic film is still covering the front of the doorbell?
KroKis
Yes, motion sensitivity 100 is set in modes (in active mode).
All protects plastics are remove.
I will try to reset and reconfigure install angule on initial set up.
  • 4 Replies
  • 1695 Views
