Doorbell
  • 4 Replies
  • 1366 Views
  • 5 In Conversation
Bigfella841
Can the doorbell be putin "standby" while I mow the grass?
Streak2
Master Master
If it's only that one camera you want off then go into settings and set the device slider from on to off.
You can always use a mode that doesn't include the doorbell but you'd have to manually switch them.
Dgmi
I was looking for something similar for my Ultra2, and was watching this thread also since I might get some doorbell cameras.
There should be like a ‘snooze’…. and you select 5 mins, 1 hr, 2 hrs etc…
I have same issue when mowing, I disarm manually, but half the time forget to arm it back on until a day later… if it auto alarms after a given time, it would be beneficial.
That control exists to supress notifications, but that won't pause recordings.
You can disarm either the camera or the system easily enough, but maybe also set a reminder on your phone so you don't forget to rearm them.
  • 4 Replies
  • 1367 Views
  • 5 In Conversation
