Doorbell camera audio issue
Dkelle7,
Are there any other devices nearby that could be emitting audio?
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I am hearing the same muffled thump thump thump on my audio when I look at the doorbell video and audio.
As much trouble as I had getting it connected I'm not disconnecting it.
Are you able to post an example video clip with this behavior? I will ask the development team if this is normal behavior.
I have a video captured from my phone but it won't let me upload it here. How can I get you the file?
Jason
I tried disconnecting it, it won't connect now.
so tired of this.
I too have an audio issue similar to this. On my new video doorbell (two days old) the microphone has a crackling wind sound. It sounds as if the wind is blowing directly into the mic all of the time, even on calm days. But what makes this sound seem worse is that it pulses (like a heartbeat). If you replay the video clips the pulses are in perfect timing to the status bar. I have very fast fiber internet and the doorbell is merely 10ft from my office router so Wi-Fi speed and buffering shouldn't be a huge concern. However, the microphone sound coupled with the stuttering signal make most of the recorded clips unusable.
I have the same issue with noisy, thumping audio. Videos start out quiet but a few seconds after replay begins, there's constant crackling, thumping. I've reinstalled multiple times and still have the same issue.
The same issue with me .opened a support ticket still waiting on their response. pretty much followed the troubleshooting script to the letter and as every poster, the thumping and wind noise is still present making the video doorbell seem like a cheap harbor freight product. Hope its a firmware issue will keep the group updated once a response is received from Arlo
By the way, I forgot to mention to the group I am a licensed electrician and all troubleshooting was done.
1. eliminating video doorbell from 24 vac transformer that ruled out AC line noise.
2. reinstalling and rewiring and resetting the unit (little pinhole in the back) To ensure connections were tight and the wires not shorting the unit out
3. Running a continuity test on the wires supplying the AC power to ensure no shorts from transformer to the unit
4 isolating the video doorbell from any interference such as my mobile phone microwave oven or any other source that would cause noise interference.
5. Eliminating the doorbell from the Arlo portal and reactivating it.
6. Changing SSDI from Guest network 2.4 GHz to regular 2.4 GHz (Please be advised it is wise to always keep your home security products and wifi thermostats and Google and amazon gadgets on the guest network for security )
7. I swapped out my router and used my backup router and that pretty much ruled out my network.
So in conclusion Its a Hardware issue or a firmware issue. on the Arlo side so please do not let them tell you otherwise. Let's hope they get their house in order.
I'm not seeing the post of your problem??? Can you let us know what it was?
The same issue as all the others on this specific thread titled ( Re: Doorbell camera audio issue) please start from the first post of this thread and scroll down and you shall be informed
(live and recordings) have the heartbeat, wind crackling sound others are describing
I did (and actually read all the posts in the forum). The problem with your method is that the mods move posts around. So it helps to be clear about it.
FWIW, I quote what I'm replying to for the same reason.
Got it. I don't have any suggestions on that one, other than to contact support. Fortunately my own doorbells aren't doing it.
wow, that is not good if the mods move the post all-around good way to confuse the unfortunate customers that are not technically gifted. But thanks for your reply it looks like it might be a bad batch hardware issue It seems the problem all cropped up around the same time frame if you look at the date of the postings just wondering if these video doorbells came from Amazon such as the one I have
Could be bad hardware. I got mine at Best Buy.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
