Doorbell Won’t Stop Recording
IWD153,
Are you using a custom mode or the default "Armed" mode? Is there anything different about the setup of that doorbell versus the other?
Hi,
Was this issue ever resolved as my doorbell started doing the same. 2wks after installation I am now getting alerts every 30secs of new recordings that don't stop.
I have had to remove the doorbell as all attempts to reset the device failed to stop the continuous recording.
I am trying to get hold of Arlo Support to assist but wanted to see if you figured it out as well.
SamN334,
Try lowering the sensitivity and see if you still experience the same issue. Take a look here for more information on how this can be done: How do I change the motion sensitivity on my Arlo camera?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
