Doorbell Mounting bracket
  • 2 Replies
  • 4979 Views
FreedMD
I purchased the kit at Walmart for two cameras and this doorbell only to unbox it and find that there was no bracket on the doorbell. I return the package and got another only to find I was in the same spot. Am I missing something about the wall mounting bracket or is there a place where I can buy a new one? I do know that they are normally attached to the back of the doorbell but it is not there on either one that I purchased
FreedMD,
If your kit is missing the required mounting bracket, please visit the following link and fill out the form to request a replacement: Missing Flat Mounting Plate
The black piece on the back is the mount (there is also an optional angled mount if you happen to need that). Follow the install directions and it will step you right through popping the back off using the little metal push pin so you can mount the doorbell.
FreedMD,
  • 2 Replies
  • 4980 Views
