Doorbell Camera Quality
Hi
Anybody else had problems with the quality or Video on the Doorbell? I know I have excellent Wifi Speed yet each time I am out and answer the doorbell it takes ages for the video to load. Sometimes the video does not load at all and the audio is rubbish so they cannot hear me.
I have looked at the settings and all seems okay and again I have fast speeds on both ends.
Is it just that the Video / Audio for these are not that good?
Yes, I am also having problems and we are tracking 300mbs in our home when the problems occur. We are leaving arlo eventhough we have about $1,500 worth of equipment from them. It just isn't a mature product for our home security needs. I need to cough up the money for a reliable and responsive system. i have had a professionally installed system before and you really do get what you pay for. Arlo was a cool idea, but it is not appropriate for protecting my assets.
Chris
jimmyboy34,
Poor signal strength due to range or interference can result in the symptoms you're describing. What does the signal strength indicator show for your doorbell? How far from your router is the Arlo Video Doorbell?
I have just installed the video doorbell and have yet to be able to see video and understand the audio. I have an Arlo camera that has worked fine in the same location. On the doorbell it shows 2 of 3 bars but on the camera in the same exact location it shows 3 of 3 bars. I have 1gig fiber internet with a new router.
Good signal strength for our doorbell. Probably within 30 feet of the router and base station. What a finicky product. The questions support asks are did you do a hard reset, did you try logging out first, have you added and removed and then re-added, did you check to see if you have power, it could be the signal strength....surfing this room and others the question should really be turned to Arlo and it should be, was this product released too early? How long was the product tested? Why are there so many tech support inquiries?
Hi
Thanks for the reply. IT has full signal and worked ok when I first set it up. The router is within 10 feet and no other obstructions are in the way. Occasionally it works ok but most times it either just has bad audio or bad video and no audio.
I have fast internet and every other tech I have works great in my house. Just this which is really bad
Hi
It is a nightmare just getting hold of anybody from Arlo. I have this problem and several others and have spent fortunes adding on products of theirs. I have tried reloading everything but the quality is just so bad
jimmyboy34,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Manolo86,
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
