  • 2 Replies
  • 947 Views
Skipperwend
Our internet is 5G.  How do I get to 2G to connect doorbell ?
@Skipperwend wrote:
Our internet is 5G.
Do you mean you are using mobile broadband for internet?
Or do you mean that your wifi router is 5 ghz?
If the latter, then most 5 ghz routers are dual or tri-band - providing 2.4 ghz wifi as well as 5 ghz.  What router are you using?
Mbateman123
I can totally help. I spent hours on this and all it took was a simple 10 minute call to my internet provider to have them split my internet so the doorbell could connect just to the 2g
  • 2 Replies
  • 948 Views
