Does the Arlo chime work with the Arlo video doorbell?
I have the pro 3 cameras, 5 camera smart plan and the 4540 smart hub. If the chime is hooked up using the hub does it count as one of the 5 cameras towards the plan or can you have 5 cameras and still add the chime?
Can you have more than one chime paired with the doorbell?
Is there a way to control the volume on the chime? If not how loud is it? I ask this as I'm very hard of hearing.
I tried asking these questions using the chat option. I was number 11 in line. When it finally got to be my turn as soon as I typed the 1 question and pressed enter I got the reconnecting message, of course it never reconnected. I'm not at all surprised given all the other problems that I have saw lately.
Yes, the chime works with the video doorbell as long as both are synced to your base. No, the chime doesn't count as a camera since it doesn't have a camera. Yes, there's a volume setting when you select a sound clip to be played by it. If you have a smartphone with the app, you also get a call on the phone when the button is pressed so you have multiple indications. I believe that you can have multiple chimes connected to one doorbell but it may be limited to 2 or 3.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
