ArloVideo Doorbell Not Connecting
Did you remove the doorbell from Settings, My Devices before trying to connect again?
You mention "soft resetting the hub" - do you have a hub or did you mean router? The wireless doorbells only connect to WiFi at the moment.
Rl-90502,
When you say it wasn't working, what was the original symptoms you were experiencing? Could you provide more details?
At what point during setup now are you seeing issues? What error messages do you see and what LED behaviors are seen on the doorbell?
Note: AVD2001 doorbell model will not connect to a base station or SmartHub, it only connects directly do your home WiFi, do you have AVD1001 or AVD2001?
Everything is working except the Video Doorbell. I have ADV1001.
Ri-90502,
For recordings to be saved to the cloud, the doorbell needs an active Arlo Smart trial or Arlo Smart subscription plan, do you have one?
Rl-90502,
Arlo Video Doorbell has no 7 day recording feature like previous legacy Arlo devices. You must have a subscription to for recordings to appear in the library.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
