Hi...
I am wondering if anyone has purchased an Arlo wired doorbell camera to replace an existing wired door bell, but then found that the Arlo device was too wide for the existing mounting space?
If so, aside from the included back plate and/or the angle back plate, what, if anything, did you do to extend the existing space to accommodate the wider Arlo door bell camera?
ThanQ in advance foe any ideas/comments...
...Thomas
In response to your reply...
I have the included brackets that you inquire about, but the spacing alongside the door where the existing doorbell is located is not wide enough to accommodate the new Arlo doorbell camera.
Hence, I was hoping for some advice regarding possible extension outward.
...Thomas
quixslvr134A,
Did you purchase the same model? If so, the mounting brackets should be exactly the same. Am I misunderstanding the question?
...Thomas
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
