Arlo wired bell
I had a new router installed and removed my old device. Now when I try to add as a new device, it does not find the device(wired bell) Please help - Thanks
You likely should remove the doorbell from your account and start fresh. The easiest thing to do is to rename the SSID and password for the new router to be the same as the old one.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
