Arlo video doorbell no power
It's possible that the transformer/wiring isn't holding up under load so the 17.3v drops as well as the needed current. It's also possible that your new transformer simply isn't supplying enough current. From the requirements:
The Arlo Video Doorbell requires a wired doorbell and chime with voltage between 16V AC and 24V AC, and a 10VA transformer.
It's also possible that it's a bad doorbell and a swap at the store can help.
how did you reset it ....if you can take it off the AC line rewire it and do a factory reset by pressing the little button in the middle of the 2 connector screws... if you get to that point and you get to the software prompt and it prompts you that its offline just press the reset button again without taking the doorbell from the power source... be careful not to short it by touching the two screws... Worked for me had a similar problem when reinstalling a replacement unit.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
