Arlo doorbell on Android - sound for motion detection
  • 1 Reply
  • 1173 Views
smt-arlo
I have Arlo setup on my Android phone but for motion detection, I get no option to select an Arlo or any other sound than the default for my cell phone.  Ergo, when something sets off the motion detection, I hear the same sound that is used by a multitude of other apps, including my email -- so I have no clue it was the Arlo Motion Detector.  Does anyone know how I can enable the [more distinctive] Arlo or any other app sounds for motion detection? I was able to do so for the doorbell itself, but just not for motion detection.  Thanks!
smt-arlo
If you press and hold the Arlo app icon, you can adjust notification sounds from the app at the mobile device level. This may look a little different depending on which Android device you have, but you should see some notifications options within advanced settings.
smt-arlo
  • 1 Reply
  • 1174 Views
