Arlo Video doorbell AVD4001 mechanical chime only works once, when pressing TEST button
  • 5 Replies
  • 492 Views
bcher
Arlo doorbell mechanical chime works only one time - during doorbell install when I push the TEST button next to "Mechanical" menu item. Mechanical chime works fine w/o Arlo doorbell (touch wires together).
If I delete the doorbell from my account, then re-install it, the chime rings during the doorbell setup procedure - then never again. I have deleted & reinstalled the doorbell 4 times - same behavior every time.
Do I need to get a power kit to fix this issue?
bcher
xfmr is just fine. when I remove the doorbell from the mounting plate & short across the wires, doorbell rings every time.
While I had the doorbell off its plate, I pulled the spring-loaded tabs on the mounting plate further away from the wall. After I placed the unit back on the mounting plate and pressed the button, BINGO! - magic happened.
Doorbell works just fine now.
5 REPLIES 5
No.
What is the manufacturer/model of the chime?
Do you know the transformer specs?
bcher
Don't know mfr of chime; it's been in the house since it was built almost 30 yrs ago.
Don't know xfmr mfr either. I measured output voltage at about 19 VAC.
It still (maybe) could be the transformer (perhaps not able to deliver enough power under load).
It also could be a defective AVD4001.
bcher
@bcher wrote:
xfmr is just fine.
Certainly in your case.  FWIW, I had a transfomer that measures 20+ volts with a meter.  The chime wasn't working properly.  Eventually I replaced the transformer anyway, and that cured it.  My conclusion was that the transformer wasn't delivering enough power under load.
Good to know, thx for sharing.  I suspect the wire connections were compressed, and there was an open ciruit.
