Arlo Video Doorbell - Splotchy video quality, no two way audio, disconnects
I just purchased the Arlo video doorbell. Just finished installing it. The directions were easy to follow which was a huge plus but that's where the good ends and the bad begins.......The two way audio is non-existent. The video quality is splotchy and pixilated. And then I'm attempting to communicate with person ringing the doorbell it disconnects before I even have a chance to hang up. My wiFi is strong so I don't understand what's wrong, did I just get a bad one? Anyone else with these problens?
BigDaddyDrummon,
These are symptoms of poor connectivity or WiFi interference. What does the signal strength icon show for your doorbell within the Arlo app?
Hello James,
BigDaddyDrummon,
Take a look here for more information on WiFi signal strength: How do I interpret my Arlo camera's signal strength?
I was told the same thing, however, I went to speedtest.net and my wifi speeds were over 100 mps. They blame it on everything but their faulty design/software.
I have three bars. My speed test is also good. I did change out my Modem with a DOCSIS 3.1 and that helped some.
My biggest issue now is the Night time vision doesn't work at all and two way communication is spotty at best.
BigDaddyDrummon,
What do you mean when you say "the Night Vision doesn't work at all"? Are you able to provide an example screenshot of what you're seeing?
Night Vision mode will not activate if the doorbell senses a sufficient nearby light source. Are there lights nearby?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
