Wireless Doorbell Charging
According to article id# 000062518, the Arlo Wire-free doorbell will trickle charge when connected to a 24V charger after the battery goes below 60% charge or something like that. My doorbell is not trickle charging. I have it hooked up to a 24V charger. I have reduced the sensitivity in terms of motion detection. I have let the battery empty, charged to 100%. All the happens it just runs the battery to 0 and no longer works. Is there some trick I am missing?!?
Can you clarify what is the charger that you are using?
Is the doorbell wired to the Ac transformer?
Can you make sure all these steps were followed to hardwire the wireless doorbell?
https://kb.arlo.com/000062491
