Mountig Plate Arlo Model AVD2001
Hello,
I would like to know where I could buy the mounting brackets for the Arlo Essential model AVD2001,
Thank you in advance
Marcus Buta
Is this a new install? Did you check all the packaging? If you'r looking for additional brackets for any reason, you'd have to use the app to go to Settings, Support, and choose your doorbell. Scroll down to Contacts to see if official support can send you new ones. Extra pieces/parts are not sold anywhere.
Hi,
Yes it is a new instal, i have look inside the box but the mounting breaket is not in the box.
Thank you for your response.
B.R.
@MarcusButa wrote:
Yes it is a new install, i have look inside the box but the mounting breaket is not in the box.
Then the best option is to exhange it with the seller.
