Hey Parnell1992
When you select the Siren button it will Give you the option to select the device to sound the siren. Then you swipe right to active the selected device. You will then have the option to deactivate the siren on the following screen. it will only sound the siren with this option.
Hopefully that helps
Hey Parnell1992
