- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Is there a way to have an Arlo wireless doorbell r...
Is there a way to have an Arlo wireless doorbell ring some type of chime inside the house?
Is there a way to have an Arlo wireless doorbell ring some type of chime inside the house? When we're home and don't have a phone nearby, it would be good to hear it chime. Thanks for any help.
Yes.
- You can add an Arlo Chime 2. https://www.arlo.com/en-us/accessories/AC2001-100NAS.html
- If you have an existing chime, the doorbell will likely work with it.
Thank you and will do.
once I get the chime, just plug it in and pair it with the doorbell?
You'll start by adding it as a device in the app.
ok and what happens from there? how does it chime when the arlo doorbell rings?
thx
Well, I don't own a chime - so I can't give you much details on the install.
It's connected through your home wifi to the Arlo cloud. Not sure the signal path is doorbell->base->chime or doorbell->base->cloud->chime, but I suspect the first path.
