Is it possible to set door bell to record longer than 17 seconds  ?
  • 1 Reply
  • 909 Views
Blacknbald
If you see "Feed" as a menu option in your app, then go into the doorbell settings and select "Default mode settings".  You can change the recording length there.
If you instead see "Library" as a menu option, then you go into the mode(s) you are using, and change the recording length in the doorbell rule in each mode.
  • 1 Reply
  • 910 Views
