Faulty doorbell?
- Battery is going down by 10% a day, started at 100% and its now down to 70%.
- live view keeps not working, I have to keep restarting the Doorbell until it works.
- When Live View works, it freezes every few seconds for a second or two.
I've tried resetting it all, changing the settings, deleting and restarting the app, still issues. Is this normal for the Doorbell?
@Pootin22 wrote:
Installed video doorbell 3 days ago, but it seems to be having issues.
How much motion activity is the camera seeing (approx seconds of video recorded per day)? If you use activity zones, then you'll need to disable them temporarily to estimate this.
This suggests a wifi issue. What signal strength are you seeing for the doorbell in the app?
But it also could be a defective doorbell. If you are in your seller's return window, it's probably simplest to exchange it there. Otherwise you can try Arlo support (using the support options in the app).
@Pootin22 wrote:
Anyone know the ideal distance the router is meant to be from the Doorbell for it to work??
About how far from the doorbell is it? It'd be hard for it to be too close, since there is a wall in between.
@Pootin22 wrote:
but still not receiving notifications.
None at all? Are you able to livestream the doorbell now?
Have you looked at these:
The router was around 5 metres from the Doorbell, which they said was too far, now its approx 2 metres, and they say that's too close. I've now moved it halfway in between 5 and 2 metres, pressed the Doorbell and still not receiving anything. Never known a router to be too close to cause issues though.
It can - the transmit signal can overload the client radio in some cases. But not 2 meters, so I think support are reaching.
@Pootin22 wrote:
The Live stream is working, but I don't receive notifications until I open the app, it sometimes works but mostly not.
What device are you using, and what version of iOS/Android is it running?
Also, it sounds like the problem isn't that you aren't receiving notifications - it's that you aren't receiving them until the app is opened? Is that correct?
If it is correct, then this has nothing to do with your router. It's totally about the app/phone.
@Pootin22 wrote:
I'm using android 11 on TCL 10l phone. I just installed the app on an old iPhone 6s and it works fine on there, so it's probably not compatible with my phone?
Perhaps not compatible - though there might be some settings that would help. Making sure "background app refresh" is set for example. I haven't used Android for a couple of years - hopefully others will chime in with other settings.
