Can’t see my library
I keep getting this notification to sign up for a plan. I don’t want a plan. I just want to monitor my doorbell through my home hub and my phone.
Are you using the mobile app or web portal browser when you get the message? If you select no thanks do you still have access to your library recordings?
Without a subscription you may need to remove any activity zones that are defined since those will require a sub.
