- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Arlo Wireless Doorbell and Chime 2 disconnecting a...
Arlo Wireless Doorbell and Chime 2 disconnecting and not reconnecting
Hi there, I have two wireless doorbells along with two chimes 2's. The purpose is to hear one entry's doorbell when I am in a different room and vice-versa. When I initially connected everything went great. However at some point the chimes disconnected. The doorbell disconnected and had trouble reconnecting at one point as well, but hasn't been causing me any issues anymore. The chimes still wont connect, and even if they do they don't ring when the doorbell is pushed. And even then they disconnect eventually. Hoping to find a solution!
Have you removed and reset the devices? Are these connected to a base/hub or to your router?
Yes both chimes and doorbells have been removed/restarted. The Doorbells don't disconnect again so long as the Chimes are not connected. They are connected to a base hub.
Another detail...The issue really start when I try to connect the chimes to the two different doorbells. When they are just connected to one it works fine with the exception of some technical difficulties, but it at least still functions. When I connect them to both doorbells it stops working almost immediately or even refuses to connect.
