ARLO essentials doorbell
Best place to mount the Arlo essentials doorbell to front door area?
Looks for maximum coverage in mounting the doorbell above to front door area. Is it practical to mount doorbell
I think you posted before finishing the message.
The doorbell has a very wide angle view so it should cover pretty much anything you need. There's the angle bracket should you need to view left or right a bit more. Generally wherever the original doorbell was mounted should work fine.
