ADV2001 Wireless doorbell cannot find internet
  • 4 Replies
  • 1041 Views
Philpug
We had the wired doorbell (ADV1001) for a year but it stopped connecting to the base station. We thought it might be an issue with the doorbell so we ordered the 2001 and would not connect either. All of our cameras work but doorbell does not. We can get the to the QR codes but not past that.
The step in set up says to connect to wifi and do a firmware update in order to connect to base station.
I scan the QR code on my mobile device to the camera on the doorbell, hear the chime but after several minutes of trying to connect to wifi, it says failed to connect.
When troubleshooting it says to check to see that I'm connected to a 2.4 GHz network, but I see no where in my phone or internet settings where I can confirm that.
Frustrated and looking for some troubleshooting that I can follow.
Look in your router's wifi settings - often (not always) there is a way to disable 5 ghz.  You can re-enable it after onboarding.
Philpug
Why would it stop working and why would our 4 cameras still be working w/o issue?
Philpug
I diabled 5 GHz and attempted to connect twice more. Still will not connect.
I've double checked that we're on the same wifi connection, same router, same location disabled 5 GHz.
Interestingly enough, I was thoroughly pleased with this doorbell camera for over a year before it quit working.
I've walked through every single trouble shooting option and even went to the trouble of purchasing a new doorbell camera. Neither of them will connect.
The need to update firmware first is because the ability to pair the AVD2001 to the base station is fairly new (added last December).
It's possible that your AVD2001 might already have the needed firmware - so one thing you could try is adding the doorbell directly to the base, and skipping the first step.
  • 4 Replies
  • 1042 Views
