Wireless doorbell won’t connect.
Someone please help ! I have “smart” wifi from optimum. So there are not two different 2.4 vs 5. My two pro 4 cameras connected but my doorbell WILL NOT. I literally just got rid of my ring and currently have no doorbell. I’ve reset. I’ve contacted support. Nothing works. Any ideas ?! Thanks in advance
Are you using autofill for the network stuff? Try manually typing in the info instead.
ewrankend,
What model is the doorbell? You can find this printed behind the mounting plate (AVDXXXX)
What LED behavior do you see when attempting to onboard? What error messages show up in the app?
So will this doorbell work with 5 GHZ?
deast777,
No. The doorbell connects to 2.4ghz.
2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
