Why can't i hear from a visitor to my doorbell
2nd generation doorbell
Do you mean you're trying to talk to the visitor, they can hear you but you can't hear them? Check the doorbell settings under Audio Settings to ensure the mic is enabled and volume turned up. You might also want to ensure the original plastic protective sheet, used for shipping, is removed.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
