Setup two-step verification not working
Received my Arlo 2K doorbell this weekend and want to install it today. However, I want to create an Arlo account first, which I have successfully done. However, after logging in, I need to set up two-step verification. I am not receiving a push notification on my phone via the app, and choosing the option for SMS does not work either. I also do not receive anything when trying to set it up via email. However, when I reset my password, I do receive the email notification. What am I doing wrong? I would appreciate hearing from you.
echoecho,
Are you still experiencing this behavior today?
Yes, still the same issue.
I also tested it on another mobile, same problem. Arlo chat does not respond at all and registering a support case is not possible because I cannot log in further. Very annoying!
Take a look at the following article and try the troubleshooting mentioned here: https://kb.arlo.com/000062579/Why-isn-t-two-step-verification-working#:~:text=Try%20to%20log%20in%20...
Thank you for your response. I have followed the article and still have no possibility to set up. In the app it indicates in Dutch "An error has occurred. Please try again" and this keeps repeating. As mentioned, an SMS also does not come through. Very annoying...
When I try to do it through a web browser and select the option SMS, it gives the following notification:
To rule out that it is my phone causing the issue, I used my work phone, a different email address and a different phone number. I created a new account via the Arlo website and encountered the exact same problem with setting up two-step verification: no push notification, no SMS, and no email when I choose any of those options.
@JamesC, hopefully, I will get a response soon, otherwise, I will return the doorbell to you and choose another supplier/brand.
I've escalated this topic to the development team for further investigation. Once we have more information available I will provide an update.
Thank you for your response @JamesC. I hope that the development team comes up with a solution soon. I would like to be kept informed.
@JamesC, can I get an update on the case? After two weeks, I still can't install and use my doorbell. Another option could be to return the doorbell and choose a different brand.
The team is still investigating this behavior. I've requested a status update and will provide more information as soon as I hear back.
It appears your network is blocking the authentication requests. Try connecting your mobile device to mobile data or a different network to see if you still experience the same behavior.
Thank you for your response, @JamesC. I don't really understand why my network would be blocking the request. I have tested this both through my wifi network and 4G, but the request does not come through on either. The same issue occurs on my work phone from a different provider with a different phone number. As previously mentioned, I have also tried making the request via laptop, but neither an SMS nor an email is received. When I choose to receive a push notification through my phone, I receive a message saying "Invalid phone number," even though my number is definitely correct.
I can understand that one of the options does not work, but both the push notification, as well as SMS and email, are not working.
What else could be causing this issue?
echoecho,
I've reached out in a private message with further instructions.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
