Indoor chime
How do I get indoor chime to work. Hooked up power source and it still only goes to my phone and not to my indoor chime
In your doorbell settings, did you pair the chime with the doorbell? Look at the bottom of the settings.
At the bottom of settings where it says added chime that is for an Arlo chime. I’m trying to connect to my existing doorbell chime. My old Arlo worked fine with it but now the GEN two won’t work
That is normally done as part of the doorbell install - I think you'll need to remove the doorbell from the account, and do the install again.
2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
