- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Arlo Video Doorbell 2K 2n Gen- Poor Battery Life
Hi- I had my Arlo Video Doorbell for almost a year and finding it impossible to submit a warranty. The battery life is terrible after being fully charged. This is extremely frustrating and would appreciate any guidance from the Arlo Community and the Arlo Tech team. Thanks!
If you have a subscription, use the app to go to Settings, Support to see the options for talking to official support. You'll also need your receipt to prove it's within warranty.
In the meantime, battery life is usually worse when recording many videos (using activity zones won't reduce recordings, just whether the recordings are deleted or displayed in Feed) and/or signal strength/quality. If you bring the doorbell inside for testing do things work better?
I have exactly the same problem. I have an Arlo 2K doorbell with chime. Battery life is now down to about one week. I'd like to replace the battery -- or failing that, replace the doorbell.
Very disappointed that Arlo isn't owning up to this problem.
Did you contact support as I mentioned above?
@Any1There Please reach out to support within the app they will be able to investigate the behavior you are seeing further. Go to settings ~ Support and follow the prompts.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
