  • 9 Replies
  • 2072 Views
  • 6 In Conversation
Kruz219
I replaced my Arlo Video Doorbell (1st Gen) with the 2nd Gen. I went through all the instructions for the "wired" option. Have had to remove and charge the camera twice within a week. Everything works fine, video, audio and doorbell (mechanical). Why is this camera not holding a charge if it does indeed have the "wired" option? Now, I have to take it down again to recharge (3rd time) and it won't charge at all with an Arlo charger and cable. ??????????
9 REPLIES 9
BrookeN
I have reached out to support regarding the 2nd generation doorbell. They will be reaching out to you as soon as possible.
Kruz219
Thank you.
almightyblk
Any response back? I also upgraded from the previous gen which was wired and I'm confused as to why this one is showing a battery (currently 88% down from 100%) despite being wired, just like my previous gen doorbell...
There is a charging threshold (I don't recall what it is, but it is lower than 88%).   The goal for that is to maximize the battery life.
SailorVenus
What does this mean? Does it start to charge once it falls below 88%?
Is there an indicator that it’s receiving power?
I set up my doorbell with a wired connection. The battery started to die since the transformer wasn’t working. I replaced it and it’s giving power, but I don’t see any indication in the app that it is receiving power. It’s currently at 94% so I’m assuming it should start charging some point…
almightyblk
I don't think Arlo has a real answer for this. My doorbell is sitting at 75% currently. Based on what support told me it should trickle charge (no indicator btw)
Screenshot_20250120_174637_Arlo Secure.jpgafter it reaches a certain number (appears to be different depending on  who you talk to).  I thought maybe it would trickle charge at night when there's no movement from deliveries, guests, kids etc. But no it doesn't. I haven't had it die on me YET so I've just given up trying to figure out why the battery even discharges if it's hardwired ¯⁠\⁠_⁠(⁠ツ⁠)⁠_⁠/⁠¯
It starts to charge when the power level drops to 65%, and stops charging when it reaches 80%
Tiffanybravo89
Any luck with resolving your issue? I’m having the same exact issue as you, I went from generation 1 which was great just had to be replaced due to sun damage. 2nd generation been a nightmare. Doesn’t hold charge, I have to take unit off to recharge it . It’s initially held a charge for a few months than I had to start charging inside my house and reconnect it once it hits 100%. Battery lasting only 12 days now. Customer service wants to trouble shoot but it’s not easy to do when out of town. So this doorbell been more of a headache.
BrookeN
Were you able to get the doorbell working as expected or are you still seeing the same behavior?
