old base as a siren ?
  • 1 Reply
  • 2839 Views
elegil
hello
i understood the arlo ultra links only to the new VMB5000 smarthub and that i can link my arlo pro 2 to this new base.
but can i use my old VMB4000 base from my arlo pro 2 kit as a siren, can it be detected by the smarthub and used it in the arlo app ?
I read in many review that the new siren inside the Ultra cameras is very weak  so i dont feel about doing the move to the smarthub if i cant use my old base as a siren.
thanks
@elegil wrote:
hello
thanks
Yes you can use the older base for the siren....
Just go to the Smarthub ( ultra base ) and edit the MODE for it... add a rule , and when you do select the other base siren.
@elegil wrote:
hello
thanks
  • 1 Reply
  • 2840 Views
