Is there a reason the battery icon would flash on and off when plugged into a usb socket rather than through a charger. Most devices today can plug into any usb outlet to charge. It may well be charging fine but that's the only time it flashes.
Are you using the Arlo Power Adapter. If not, see this article:
Brian
Thank you for the link, I do have the adapters but was hoping to eliminate a piece. Now I'm wondering if a regular usb will operate the camera OK since I'm wiring them my understanding is a battery isn't even needed.
The cameras without the battery will run on a 5v usb of about 2a or better
it will not charge a battery at 5v cause the battery gets charged to 8.4v
Thank You
confused - so I thought if the cameras work wired, why not just forget the batteries so I plugged them back into the outlet usb's and no flashing batteries this time and they all charged fine.
Well I thought things were OK but then the batteries were almost full at the time of my last post. Now not only do the battery icons flash but the batteries also discharge. OK so to check it out get out the step ladder and the charger and cable I've been using for 4 months now issue free on all six cameras and same thing. Stick in an Arlo charger and it's fine.I've been using this for 4 months just fine and faster than my Arlo chargers, it's appearing more like Arlo might have done a software change to prevent using things not produced by them. If this is the case it could be the same thing Apple just lost in court. IF
after further research not only does the Ultra run on 5 volt 2 amp, that is also what the power adapter that comes with the cameras for charging is rated at and it works so there is no reason for mine suddenly not to.
Accessing Local Storage
