we installed arlo ultra 4 cameras but need 3 more cameras. We plan to buy another smart hub with 3 cameras.
can this be managed in the same internet environment, and in the same arlo app?
Yes, you can run quite a few cameras on a single base... ( I have 12 of all models currently )
Only issue is the bandwidth for the Ultra... believe it's 2MB up per camera.
And then there still is the max of 5 cameras streaming per base ( but you can run multi bases all from the same app )
With the Ultra, you may want a base at each end of home for better coverage
Accessing Local Storage
