Will the Arlo Ultra cam work with an Arlo pro base?
Will the solar panel that works on Arlo Pro work with Ultra? If not is there an adaptor ?
If the Ultra cam won't work with the Pro base, can Arlo Pro cams work with the Ultra base?
Thanks.
Thanks.
The Ultra camera will only work on the Ultra base ( smarthub )... but you can use all your older cameras on the Ultra base too.
Thanks.
Thanks mate.
One more question, I have spent a fair bit on solar panels for 3 cams, the new Ultra cams dont have the same connections , is there an adapter that can fit the solar panels to the new Ultra cams?
Mobis,
Mechanically, there are some differences between the two solar panels. There is not an Arlo adapter you can use to allow this.
Accessing Local Storage
