WB4540 hub does not record any more
Reboot the hub. Eject the drive and check on a computer to verify you are or are not getting recordings. Check your local storage settings in the hub's settings under Storage Settings. Format the drive again using the app. Make sure the drive is at least 16GB. Try a different drive.
Accessing Local Storage
