The development team released a cloud fix late last night that resolves this issue. Thank you for all the confirmations that the fix is now allowing push notifications to be received.
Just subscribed and have the current firmware and App - live in Australia - subscribed to Premier Plan
I do not receive Rich Notifications as advertised - text only, no photo/picture on Samsung S8+.
The "Call a Friend" and e911 option is also not available, and does not appear as a menu option.
All camera's are active
Arlo, I’m no longer receiving push notifications from my system; however, I still live camera vision and library downloads. I believe it’s a problem with your new app. The system was working fine yesterday.
Software and notification settings. I have re-I stalled app numerous times, re booted base station and my modem as well as reading all other suggestions in the forums on here regarding the issue.
I am running iOS 13 and the most recent app.
Very frustrating, not much point having cameras if I am not being notified when they are triggered.
I bought my cameras today - same issue. Have tried turning notifications off and on in both the arlo app and iOS settings. Have set zones and power cycled the base station as well as deleting the app and starting over. Not a great introduction to the product seeing they were purchased specifically to be notified of movement. Would love to know when arlo plan on fixing this issue.
I received a email from arlo pretty much stating. try turn it off and on again. Please share if you get it resolved. Thanks.
Version 2.9.1
IoS 13.1.1
2 days ago app stopped sending push notifications, email notification still happen. The most important part of the system which are the notifications have stopped working. Tried everything from reinstalling the app to resetting the smart hub. Nothing has worked so far
Can you let us know the actual app version?
There are a number of posts about this. There appears to be a problem with the app under IOS 13. Arlo are aware of this and are working on a fix.
Is the legacy app also installed on the iPhone/iPad?
If it is, try uninistallng it.
Very frustrating!
You might want to contact support ( https://www.arlo.com/en-us/support/contact.aspx ).
That apparently can also be frustrating, but still would be the next step.
Do you have a paid subscription, or are you using the free basic plan?
I've got app version 2.9.2_2593 which I pretty much updated to when it came out on android 6 . Initially it seemed to notify on most notifiable events but I'm sure it missed a few per day as did the immediately preceding versions but the videos were in the library. The last couple of days though, I've got no notifications for my ultra system but heaps should have come through. On the other hand my arlo pros ARE reliably sending through notifications.
My wife's phone who's arlo app I only updated yesterday (was on about 2.8.1 ish maybe? Certainly post legacy app) had the same lack of notifications for the last few days.
This looks like a back end issue to me. It would be good if Arlo notified when the backend was updated like they do for firmware updates.
My wife's I-phone is still getting them perfectly but then she still hasn't updated to ios13. My S10 which was working great for 3 weeks since dealing with support about doze mode suddenly quit working again 3 days ago whenever it goes to doze.
It's not just iOS. I've got the same on Android.
Also why does status.arlo.com always report 'All Good' when clearly it's not.
Accessing Local Storage
