I live in Miami, FL and every so often there are sudden showers which may carry sporadic wind gusts up to 40 mph.
Even though the magnets are quite strong, I am not sure if the camera will remain attached after a strong wind gust.
Those Arlo Ultra cameras aren't cheap (at least for me) and I just don't want to find it blown off its magnetic base after an unexpected minor wind gust.
It does have some weight to it...
If concerned, then I would just use a threaded camera mount. Either from Arlo or any standard camera mount with a 1/4-20 thread will work
As TomMac mentions, if you're concerned with the stability of the magnetic mount outside, consider using the Arlo Security Mount (VMA1000). You can find more information on these mounts here: Arlo Products and Accessories
Thanks for your assistance.
I to did not trust them in wind which easily hits 60 mph with gusts here in the PNW. I found them to easy to knock around and so only kept one for charging until accesories came out. After adding skins the magnetic ability is even less, reaching for it for charging I bumped it rather lightly and it landed on my sidewalk. The best advice is indeed the screw mounts. I purchased the originals at BestBuy with my only wish being they would have been shorter. The 4 camera set I purchased came with 2 magnetic and 2 screw mounts. The scew mounts are shorter than those from BB and I wish those were available.
Accessing Local Storage
