Ultra recording bug?
Have you experienced this?
At 5m30sec into https://youtu.be/lNVAjt72Leg
is where I heard that there are no recordings if your internet was down. He mentions notifications first but then also recordings. Hopefully we can get someone on the forums to test it to see if maybe his experience was a fluke. Perhaps it was an issue that has now already been addressed or if not then maybe we can get it fixed as it obviously shouldn’t be a thing.
Minlas,
Do you have local storage enabled? Are you experiencing this issue personally?
As I mentioned above my source is the YouTube review video linked and hence why I was trying to get other users feedback if they could verify this on their system or had experienced this. Also to find out if maybe it was perhaps an isolated incident the reviewer had experienced or a bug that had already been fixed etc.
11:03
https://youtu.be/RWJZa-u8OWk
Also when specifically rebutted on this point by a YouTube user (not me) in the comments below in a screenshot of the YouTube reviewers’s adamant response.
That’s two (and I believe I heard this information in several more YouTube reviewers) on two different Arlo outdoor wireless cam products that they found this issue but no one here experiences it when they check?
@Minlas wrote:
... but no one here experiences it when they check?
Not sure I'll have a chance to check it anytime soon. There are quite a few scenarios here that might behave differently
- disconnecting the base station LAN with the base running
- disconnecting the router WAN with the base running
- booting the base with the LAN disconnected
- booting the base with the router WAN disconnected.
5-8. Test all the above with and without cloud activity zones enabled
And in the case of the Ultra, the USB recording won't be a backup as soon as the direct access to local storage feature is released. So the test would need to be redone again when that feature is released.
The youtube test was similar (but not identical) to [2], and there was no indication as to whether cloud activity zones were enabled or not.
FWIW, I believe that the reviewer's conclusion in the comments that the USB video is backhauled from the cloud is in fact incorrect. We have quite a few reports here of
- local recordings that are not in the cloud at all
- recordings that are corrupted in the cloud, but not in the local USB storage
Neither of these would happen if the USB recordings were backhauled from the cloud. Even if it were done that way today, backhaul from the cloud makes little sense once the direct access to local storage feature is release.
There are indeed several scenarios that have value to be tested. The by far most desirable and by far more valuable/reliable for a security camera setup is one where as long as the cameras can communicate with the base there will be recordings. This if course contradicts with what the reviewers have found with again even if the internet goes down there aren’t local recording which surely, if true, is just an overlooked serious bug.
Accessing Local Storage
