- English
- Arlo Forum Discussions
- Arlo Ultra
- Ultra issues including recording at night. Wrong c...
Ultra issues including recording at night. Wrong case and RMA issue.
- Email to a Friend
Let me first say if this gets categorized wrong it's because of the Label which only allows (Arlo Smart, Arlo Mobile App,) to be selected. I will also add the system will not upload the picture, but it's attached to the case.
I've had case 41787259 open for ever and can't get anyone to assist. Had RMA 7149888 approved on 7-29 and can't even get that completed. It's impossible to talk to anyone live and I have asked for someone to call me multiple times.
I've documented all the issues and even show support major issues with recording at night. Below is what I sent support again this morning after they looked at an RMA from 2019 on what I think was my Pro 2. Look at the attachment at least the third I have sent with no recordings occurring even when the Pro 2 captures it correctly.
Can anyone here assist? This is beyond frustrating!!!
Wrong Case Wrong RMA, what you listed is from 2019 and if that actually is for me it was for the Pro 2 when it broke. Why are you looking at previous cases that don’t even apply to the Ultra Cameras? The RMA on this open case is 7149888 Which was approved on July 29, 2020. Again this needs to be escalated to someone that can actually fulfill the request and work on the actual issue not look at the past which is not even the correct station.
Arlo Ultra has major issues recording at night. Here is at least a third example I have given you on this issue. The recording if from a Pro 2 Camera, The Pink shows where there are 2 separate Arlo Ultra Cameras. The one Ultra camera is mounted beside the Pro 2 Camera. You can also even see the one by the Garage has a light on however neither one of the Ultra cameras recorded a video. Its quite obvious they should but neither of them recorded a video.
No there is not issue with range or interference of the camera’s to the base station, I’ve explained that multiple times as well. I’ve asked for call backs so many times because it’s impossible to get a hold of a live agent.
Now someone escalate this to fix it, because you have an issue in your software, hardware, Arlo Smart Plan, or all of them.
- Email to a Friend
Hey Hoagie,
Let me reach out to you via private message to gather more information from you.
- Email to a Friend
- Email to a Friend
I received your private message and the image you attached as well. I've responded to your private message so hope to hear from you soon.
- Email to a Friend
I gave support multiple other pictures they are not sure what the issues it. But the Pro 2 Camera shows that the Ultras have issues recording at night.
- Email to a Friend
I'd like to also add I have done the same tests with the Ultra 2 and it has the same issues.
- Email to a Friend
- Email to a Friend
- Email to a Friend
Hi RDStorm,
- Email to a Friend
Took 3 months to get a replacement base and that did nothing. I have a Pro 2 beside the Ultra and it records about 2 times as many videos than the Ultra does. The Ultra also doesn't do push notifications for sound. It's an obvious software and/or hardware issues impacting performance. It could even be part of the Smart Notifications software.
