HazzMatt
I've spent hours per day over the last week trying to figure out why some of my Arlo Ultra Cameras stopped recording on motion.  I have two different Ultra systems on two different accounts in two different states and both systems have this problem. Symptoms are:  Arlo app shows last activity hours ago on some cameras, when I know there was activity during this time that should have been recorded.  No recordings in the library for those certain cameras either, no surprise there.  I've spent hours resetting batteries in cameras, rebooting the base station and even factory reset the base station and then rebuilding my cameras from scratch. The problem re-appears and it isn't always a specific camera that stops recording. The problem moves to different cameras. I do have some cameras that have a weaker signal that the others, but it isn't the weakest camera that always goes to sleep.  Sometimes the weaker one will stay working but the stronger cameras can also be the one that goes to sleep instead. The only way to "wake up the camera" seems to be to either remove and resync the camera or reboot the base station. Despite a short restoral period, the problem appears again.  After hours with Arlo Chat, going through the painful processes they must ask you to do or try - nothing got fixed. I finally got escalated to Level 2 support. Finally I was informed that the Ultra Base station received a firmware update on July 29th -the "exact day" that my problems started.  My fault for not checking the Arlo website for a list of recent updates - it was there, Arlo Ultra Base update on July 29th.  Unfortunately, Arlo cannot revert to the previous firmware version.  At present, they don't know what came out in that update that "broke things".  Anyway, I hope this report helps others to avoid the painful amount of wasted time troubleshooting that I've spent.  Oh, another thing - I also have Arlo Pro cameras at the same location and they all work fine, they don't have this problem.    Last thing: I've seen many claim that the Arlo Ultra systems don't have the range to cameras that the Arlo Pro has/had.  I also have seen this.  An Arlo Level 2 technician told me today that is absolutely not possible or true. If the power and sensitivity isn't less, the antenna pattern must be different. The result -not as good of range.  I hope this helps at least one person! Take care and Good Luck!   Matt
120 REPLIES 120
pjama
Luminary
Luminary
> Do you see the video files on your SD card too?
Bingo!
I've just discovered a 2 hour window this afternoon where some 30 vids were recorded to SDcard but not up to the portal and no notification. My internet access was working at the time as netflix was being used and consuming about 2 of 40Mb/s bandwidth (based on same use right now).
It seems to me the cameras are detecting and recording ok but there's something flakey about comms between base station and arlo cloud.
As an aside, previously I've noticed that the arlo infrared is on thus it must have sensed motion but no notification or vid on the portal.
n1976jmk
Virtuoso
Virtuoso
Same here, at night and the early mornings I see the led infrared lights coming on my Ultra cameras but no app push notifications, or motion events being recorded to the library 😩😩😩
Engie97
I have had the same issue with one of my Arlo ultra cameras starting July 31/August 1. It detects motion, I can toggle the spotlight remotely on and off and through motion and all works correctly. It will just not auto record motion or audio activation. I can manually turn on and it records fine.
n1976jmk
Virtuoso
Virtuoso
Engie97, did you open a case for this with Arlo support?
So Arlo support can see how many people are affected and hopefully that’ll get it fixed faster.
Thanks,
SuperZwu
Arlo support just sent me an answer after 3 days of waiting. The guy told me that the Ultra System demands more storage space as available for my account so I would need to sign up for one of their subscription plan BUT for Austria this isn’t possible at the moment!
Sorry Arlo but that’s unacceptable!
You advertised your system is working WITHOUT any monthly payment and it was working till last firmware update and now you are trying to force us all to subscribe to your monthly payment plan!
THAT IS RIDICULOUS!!
HazzMatt
That doesn't make sense.  I have the Arlo Smart subscription and my cameras just "go to sleep" as far as motion recording goes.  Some cameras still operate and the problem rotates between the various cameras. Last night I was told the problem, which started on July 29th, was "identified" and that another firmware update would be coming soon.  So, I'm thinking we have different problems, but somewhat intertwined as both our problems occured after the July 29 firmware change came out.  Good Luck to all of us.
Mjbeuke
What!?!? You’re right - that’s completely unacceptable.... it’s recording in 1080p if your not paying for the 4K recording - so why in the hell would you have to pay for the 4K that is OPTIONAL??
My god Arlo - get it to frikking gether if that’s even within your scope of capability...
This issue has been raised and the development team is currently investigating these reports. I will provide an update as soon as I know more.
HazzMatt
Hello JamesC, what was contained in the July 29 Ultra Base Station Firmware Update that caused these problems for your users?  Are you saying that this is only now being documented by Arlo?  I've had a ticket in for several days that states that motion recording "goes to sleep".  My report is very detailed and lists all the steps taken on my end to attempt remedy. I have two separate systems in different locations, different service providers in different states that have the same problem -- and both systems were fine prior to July 29th.
Mjbeuke
Same problem since the last update and still doing it.... motion sensing it working in the Ultra at my front door and back door - but no recordings or notifications since the last update.
There are several threads on this same issue now - one guy owns 2 systems in 2 states doing the exact same thing....
@JamesC is there art update on this one??? Of the countless annoying issues that constantly arise with my Arlo system - this one tops them all....
No recordings is simply unacceptable. It’s literally the point of having these cameras.....
Mjbeuke
Yep there are now 2 or 3 other threads on this exact issue - and it started at the point of the last SmartHub "update".....
Cameras won't detect motion/record at all.... Rebooting the base station fixes it for a few hours - but its unacceptable to have to do that for a SECURITY CAMERA....
As was suggested - anyone experiencing this issue please call in a support ticket. Don't bank on hearing back from them ever.... but at least its documented and multiple users complaining of the same issue should rise it up on the priority fix list....
@JamesC here's another thread for the same issue.... Its widespread and we would love for it to be fixed ASAP! Thanks for anything you can do to get Tier 2 Engineering (and above) involved to snuff this one out ASAP!
OneofKind
I certainly did and they didn’t seem to give AF. The guy told me to bare with them while they try and work out the bugs!! They should have done all the testing long before it’s out in the market.
I’ve now returned this system and will never ever buy Arlo **bleep** ever again... Absolutely useless.
Retired_Member
Not applicable
We purchased the Ultra system on August 4.  We have been disappointed in how the Ultras detect motion.  Given the high cost of this system, we are thinking of taking the system back for a refund.  In our front yard, we previously had a Pro camera which did a good job of detection motion on our driveway and walkway.  We replaced it with an Ultra.  We were having great difficulty in getting it detect us on the driveway well within 25 feet.  We must have spent an hour adjusting it's angle to get it to pick up motion on the driveway.  It does not pickup motion on our walkway. Disappointed.  So, it appears to us that the motion detection range for an Ultra is much smaller than it is for the Pro.  We were going to put the Pro back up (take down the Ultra) but then decided to instead use the Pro attached to metal on the side of the driveway.  We then configured the Pro, that when it detects motions, to also turn on the Ultra recording.  This is basically using the motion detection function of the Pro to get the Ultra to record.  This is really cheating, working around the motion detection shortcomings of the Ultra.  We will give the Arlo softward team a bit of time to resolve the Ultra motion detection issue.  If it fails to, we will take back the Ultra system as there is little point to have an expensive security system that continues to fail to propertly detect motion.
It is really odd.  We struggled getting the Arlo to detect us on our driveway, yet a few times it detected vehicles out on the road on the far left of it's viewing window.  We have the Ultra set for 180 degrees.  This ended up showing a small part of the road on the very left side of the viewing window.  To our surprise, the Ultra noticed car motion on the road a few time.  The cars would be about 40 feet away from the camera.  Not sure why it could notice this far away motion, yet be challenged in noticing motion within the 25' range.
Qia
To the Arlo team
somebody has the solution for this big issue?
since almost a month and 1/2 ,2 ( out of 4) stops records motions to the library.
I tested  them ( motion detection test) and, was good.
call Arlo support, open like 4 cases, and until today nothing happens.
one more time, anyone knows what goin on???
are you going to release pretty soon another update to fix the problem?
and guess what, another camera star with the same problem today,which is means that I have only one on “ service “.
How long we( customers) have to wait for a real solution?
Also the smart notifications, send me false alert, confusing “ cars” with Animals 🤭🤭, and “ motion “ and you will see cars, 🤭🤭🤭.
all that stops, because don’t record nothing.
Gloryrob
I have my two ultra camera system connected with four pro 2 cameras . I been having this issue with one of my ultras for a while now . It records and sends alerts for a bit . Then for no reason it’s stops sending alerts and doesn’t record. When it doesn’t respond I need to restart the base then it works for a little while . Then it stops recording. The weird thing is I don’t have this problem with my pro 2s and my other ultra . I have the same settings that my other ultra Has and the pro 2 . Nothing different I don’t understand why this keeps on happening to this particular camera . I just received this new camera from arlo under my warranty. As I was having issues with the defective camera I sent back because it completely stoped recording and sending alerts. I have a custom mode as well with the camera that’s giving me issues it does the same thing . Even when I stand in front of the camera jump around or do hand movements nothing works to trigger it . I’ve deleted the camera and installed again. No luck
I noticed many people having this similar issue as well .
HazzMatt
I made a similar post, and others responded saying they have the same issue.  Our issues started on July 29th as a result of Arlo's Ultra base station firmware update on that same day.  There is no word of a fix.  You stated your problems started much farther back.  If you issues started before July 29th, then maybe our problems are not the same.  My motion recordings were fine until July 29, but it took me nearly a week before Arlo had told me of the July 29 update.  Shame on me for not noticing the firmware update myself, but I didn't know that Arlo posts these notices or where they were.  Good Luck to all of us!  I now have two essentially worthless Arlo Ultra systems until this problem is resolved.
HazzMatt
Welcome to the club.  This motion recording failure for the Ultra's started on July 29th after they sent out a Ultra Base Firmware Update.  Arlo engineering supposedly knows about it and is trying to fix it, but it's now been two weeks since the bad update came out and we seem to be no closer to having our Ultra systems working again.  Of all the issues I've had with Arlo when I started with the Pro cameras, this latest Ultra issue since July 29th seems to be the worst.  Good Luck to all of us.
Jaydius
Glad to hear I’m not the only one.  Hopefully the fix isn’t far away.  Upgraded to the Ultras just recently and have had problems ever since.  You'd think they would conduct substantial internal testing before pushing firmware updates out to the community.
Very concerning a security camera system can fail so catastrophically and without warning.
HazzMatt
I chatted with Arlo again an hour ago and still no update news, other than they're working on it.  The only real good news is that there are no more frustrating tests and troubleshooting steps for me to do.  So instead of running around and being angry, I just wait for the fix to come out, but I'm still angry.   Good Luck
HazzMatt, Qia
Do you have local storage enabled on your SmartHub?
n1976jmk
Virtuoso
Virtuoso
Hi @JamesC. I have local storage recording enabled on my Ultra smart hub as well.
Thank you!
n1976jmk,
Could you try disabling the local storage (as an isolation step) to see if you still experience the same issue.
n1976jmk
Virtuoso
Virtuoso
Sure JamesC, to clarify though would you like me to disable or remove the microSD card?
Thanks!
n1976jmk,
Please disable and remove the microSD card.
Kammfam
Luminary
Luminary
I don't know how I missed this thread. I have a similar thread ("missing motion...") complaining about how my Ultras just seem to doze off every so often but then work fine 5 minutes later. It also seems to be just my Ultra cameras, and it's all of them at the same time. It's like the cameras are busy doing something else and don't work for a few minutes. I miss motion almost daily, as in someone will walk directly in front of the camera, nothing... then walk back by 5 minutes later, and the camera will trigger.
