This problem has resurfaced with the newest firmware update.
Was fixed awhile back, but now audio is choppy and stuttering.
Can you please do what you did last time to fix this issue in the next firmware update.
my live view has had stuttering audio AND video since day one, its like people are walking around in slow motion, despite my camera bandwidth showing STRONG in the arlo app.. just assumed it was one of the many arlo flaws and dealt with it considering getting into live view takes so long anyways it defeats the purpose of it since by the time it takes for the process to load it up the event is usually long gone and finished.
a slightly more helpful reply to my above comments, Ive noticed that sometimes it helps to go into 2 way audio mode and that can remove the stuttering audio, but to me its a gimmick option to have when it takes 40+ seconds to get into live view to start off with, if I left someone standing at the door that long they would just assume no ones home..
