I have an Ultra camera. Works fine with battery alone. When connected to a solar charger, though, it says "A charging fault has been detected..." As soon as solar charger is disconnected that error goes away. I disconnected charger. I unplugged cables. I reconnected cables and charger. I removed and replaced battery. I even connected a second totally different solar charging unit. Same error.
6 REPLIES 6
By the way, battery is 95%+. Sunlight is direct.
Swap at the store.
Right. Very hepful.
Thanks. I already did so. No response.
Hi @Arlo202
I have opened a case for you. Customer Support will be reaching out to you as soon as possible. I have provided the case number for your reference: 41715598
Accessing Local Storage
