Replaced Base but cannot connect to WiFi. Ethernet directly plugged to modem.
  • 2120 Views
Jimalex1957
Three  calls to Arlo Customer Service and no resolve.  They will replace  the base hub but here is the  problem:
Base Hub cannot connect to wifi.  Ethernet is plugged directly into Mediacom modem (LAN 2).  Then tries to connect to my RockSpace Mesh system but cannot make the connection.  Solid blue light on basehub.  All my other devices are working fine on the wifi...what gives?
It would seem that this is due to the base getting a second IP address from your ISP rather than your router. Plug the cable into a router port so the base is on your internal network. If you don't have any additional ports on your router, a switch or WiFi extender may be needed.
Jimalex1957
We are in business..I simply plugged it into one of the mesh routers downstairs and the hub immediately found it.  Arlo please take notice..hire this guy.  He could have  saved me three phone calls and you sending me a new device (which I will send back).
No thanks. I'm retired IT and have no desire whatsoever to ever work again.  🙂
  • 2121 Views
