Recorded video audio is not working properly
Doesn’t work properly how it should be working. I don’t even get sound recording with the video taking at all like it did before. I advise you to fix the problem.
Hard to tell with so little information from you.
What are you doing and where does it go wrong?
Just another user
@Shkreli007 Is it all recordings from all cameras not having audio or just one? Your not giving much information like @michaelkenward said.
How are you playing these videos? On a mobile device with an app?
This will sound strange, but one user had the same problem and discovered that they had turned off the sound on their device. The videos were fine, but the volume was turned off.
Have you tried viewing with something else?
Just another user
@Shkreli007 Have you tried it on the web. Do you hear the sound on the web client my.arlo.com on PC ?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Accessing Local Storage
