And the record button from the live image seems it has disappeared to.
I attach a picture from 10 meters hight, the same spot where the Arlo HD trigger the sensor even in the dark.
Mihnea,
Positioning plays an important role in whether or not your Arlo camera can detect and record motion. Take a look at this article for tips on positioning for best performance: How do I position my Arlo Ultra camera to detect motion in specific areas?
For Ultra to save recordings to the library, you must have a subscription plan. To have a subscription plan, the system must be set up in an eligible country. For more information on subscription plans and where they are available, take a look here: What are the available Arlo subscription plans and how much cloud recording is available?
Plan Pricing it’s a different thing.
I have also an Arlo HD that works great in Romania. It saves recordings in the library and the app gives me notifications when the sensor is triggered. The Arlo 4k does nothing of the above.
I,v remove the cameras from the app and then install them again. I have remove the device from the app and install it again. Nothing.... no notifications.
Or the device was defective...or you have an app error.
Mihnea,
Given the issues you are experiencing, I recommend contacting the Arlo Support Team to inquire further. You will find several options for contacting support in the provided link. Please let me know if you need assistance opening a case.
Accessing Local Storage
