Password for base station
I want to know the password so that I can connect a range extender and not spend $300 on another basestation
Password for what?
The wifi from your base station is "closed": you cannot access it.
You cannot connect cameras to a wifi range extender. If they cannot communicate through the existing hub/base station, there there is no alternative to adding a second base station. You can then wire that into a range extender.
Just another user
Accessing Local Storage
