Greetings,
it's the second time that I purchase Arlo in the last two months, the first I returned the product to the seller within 14 days because the base was unable to connect to the internet (orange light flashing).
I then discovered that an unpublicized requirement of the service was to have the IP reachable from the internet,and i was under NAT; for this reason I contacted my ISP (a 1000mbit optic fiber operator) and I requested the transition to the public static IP.
Last week I got it up and running and I've been "reachable from the outside" since then; I therefore proceeded to buy back the Arlo Ultra system, but, surprise , this time too the base couldn't connect to the internet by flashing orange indefinitely.
I opened on my router (fritz.box 7530) ports 80, 443 (tcp) and 123 (udp), without getting results.
Before I decided to return the product again, I wanted to understand if there was any other test to be performed
Thanks a lot to those who will help me
Hi @n3kr0s
I have a few questions for you.
- Have you tried to reboot you router & test again?
- Did you successfully setup the base & cameras & the Orange light followed after?
- Have you tried with a different ethernet cable?
Accessing Local Storage
