Hi. With offline storage on the micro SD card...
- How long does it store the video offline? Is this 30 days or 60 days ie. does it match the plan that I'm subscribed to or is it just until the card is full and then re-writes over oldest? I'm hoping the offline storage ISN'T linked to the plan in any way.
- Just wondering also... I've noticed that micro SD is saving SD and 4K video (in the app base station settings)... if I subscribe to 4K video plan, will is only save 4K to the SD card? Or perhaps it used the SD for image detection of people, pets etc. But I've turned off smart for motion detection.
1) ANything stored on the SD card remains there until you remove it. It has nothing to do with your subscription.
2) 4k works by itself - if you use Zoom and Tracking, you get 1080p.
Accessing Local Storage
