Hi, 1 of 3 camera has stopped charging after 3 weeks.
Have mixed battery, cables and charger without luck.
All 3 are connected with cable.
Any ideas?
If you have cleaned the contacts, the next option would be to contact Arlo support re warranty
Thanks for your suggestion, I can always try to clean them but think it is strange that it just happened after 3 weeks.
Mounted inside, no dirt...
Accessing Local Storage
